Precise, rigid, high load Slide Guides from NB
SGL Slide Guides from NB Corporation are high-precision, high-rigidity, high load capacity linear bearings with low friction, non-stick or slip mechanisms that provide smooth linear motion even under high loads.
SGL Slide Guides are available in lengths from 160 mm to 3000 mm. Six types of blocks are available depending on the mounting space and desired mounting method. Three accuracy grades offer the right Slide Guide for every high-precision positioning device or high-precision machine. The number of tracking grooves for ball elements or rows of rollers varies by the type of guide and the width. Both retained and non-retained ball elements are available.
The range of NB SGL Slide Guides includes products for demanding applications as well as products for standard industrial applications. Detailed drawings and tables provide dimensional and mechanical information, and 3D CAD files are available.
slide guides
NB Corporation
Filed Under: Ball + roller guides, Industry news Tagged With: nbcorp, Nippon
