Acme or trapezoidal? What’s the difference between lead screw designs?
February 4, 2020 By Danielle Collins 1 Comment
In power transmission applications, there are two primary types of screw drives: those that use recirculating balls or rollers, for applications that require high rigidity, excellent positioning accuracy, and high duty cycles, and those that rely on sliding contact, for applications that require corrosion-resistance, self-locking operation, and customizable nut designs.
The second category — screw drives with sliding contact between the nut and the screw shaft — are referred to as lead screws, Acme screws, or trapezoidal screws. And although these names are often used interchangeably, they actually refer to different screw geometries and dimensions.
Here’s a breakdown of the different types of sliding contact screws and what the terms “lead screw,” “Acme screw,” and “trapezoidal screw” really mean.
Lead screws
The most commonly used of the three terms, “lead screw” simply refers to a type of power screw that relies on sliding motion between the nut and the screw shaft. There are two variations of lead screws: those with square thread forms and those with trapezoidal thread forms.
Lead screw designs for power transmission almost exclusively use trapezoidal threads, which are easier to manufacture and have higher load capacities than screws with square threads. Trapezoidal threads, however, do have higher friction, and therefore, lower efficiency than square thread forms.
Acme or trapezoidal screw
Lead screws can have either square or trapezoidal threads.
A power screw is a screw that transmits power by converting rotary motion into linear motion. Lead screws and ball screws are types of power screws.
Acme screws
As mentioned above, lead screws for power transmission use trapezoidal thread forms. But the trapezoidal thread design can have a thread angle of either 29° or 30°, meaning there are two versions of trapezoidal lead screws.
The first version — referred to as an Acme screw — has a 29° thread angle and is manufactured in inch dimensions. Acme screw sizes are typically specified by the screw shaft diameter and the threads per inch, or TPI.
Lead Angle
Trapezoidal thread forms with a 29° thread angle are referred to as Acme screws, while trapezoidal thread forms with a 30° thread angle are referred to as trapezoidal screws.
Image credit: Roton Products, Inc.
Fun fact: Acme screws were developed in the mid-1800s to replace square thread screws. The name “Acme screw” came from an employee of the Acme Screw Machinery Company in Cleveland, OH, which manufactured multi-spindle lathes. (See pages 13-14 of this scan of American Machinist Magazine from 1985.)
Trapezoidal screws
Trapezoidal screws are also lead screws that use a trapezoidal thread form, but trapezoidal screws have a thread angle of 30° and are manufactured in metric dimensions. The size of a trapezoidal screw is designated by the screw shaft diameter and the pitch of the screw threads. Trapezoidal screws are sometimes referred to as “metric lead screws” or “metric Acme screws.”
lead screw hierarchy
Acme screws and trapezoidal screws both use a trapezoidal thread form, but they have different thread angles.
Refresher on screw thread designations
Pitch is distance between adjacent threads on the screw shaft.
Threads per inch (TPI) is the number of threads that can be counted in one inch of the screw. Pitch and TPI are the inverse of one another.
Lead — typically used in ball screw nomenclature — is the linear distance traveled per revolution.
  • How can lead screw backlash be reduced?
  • What is a follower nut, and what role does it…
  • lead screw
    Motion Trends: Applications expand for versatile lead screws
  • lead screw
    When should you lubricate a lead screw?
  • Lead screw selection: What should I consider besides diameter and…
Filed Under: Ball + lead + roller screws, FAQs + basics, Featured
  1. Herbert Maxwell says
    March 17, 2020 at 2:54 pm
    Very important and useful information
Leave a Reply Cancel reply
MOTION DESIGN GUIDES
Follow us on Twitter
Tweets by Linear_Motion
