    • Cam + wheel guides
New bearing from igus assists in quick, easy liner replacement
June 6, 2018 By Miles Budimir Leave a Comment
igus has introduced a new bearing, drylin W Exchange, for its drylin W linear system in which the liner can be replaced directly on the rail without dismantling the system.
By using a practical assembly tool, users can push the old liner out of the housing, clip the new one on to the shaft and push it into the housing for a flush fit. The quick and easy swap of liners will save engineers time and money while maximizing machine up-time.
“When changing the liner on the linear glides guide rail, for example where extremely abrasive sand or glass dust is present, the entire linear slide has to be pushed off the rail,’’ said Robert Dumayne, director at igus. “For linear axes or multi-axis gantries with a toothed belt drive, this requires a high assembly effort and long machine downtime.”
linear bearing
The new bearing housing for the drylin W linear system ensures easy changing of the liner directly on the linear rail. The side cover of the bearing housing on the linear slide can be removed easily with a screwdriver. The liner is pushed out of the carriage and removed. The replacement liner, which is made of highly wear-resistant and abrasion-resistant iglidur J200 tribopolymer material, is clipped on to the rail and inserted precisely into the slide with the assembly tool. The change is completed by putting the side cap back on the bearing housing. The assembly tool is supplied free of charge, and it can be 3D printed.
The practical benefits of the drylin W Exchange is that the rail cannot be damaged, and replacement takes place directly on the system. A pin in the middle of the side cover secures the liner on the carriage. It can also be replaced using a screwdriver. In this instance, igus provides special recesses on the new liner and in the carriage.
The new Exchange bearing housing can be retrofitted to all existing drylin W systems of size 10 with a shaft, including guides, linear axes and linear robots. Additional sizes are currently being planned.
For more information, visit www.igus.com.
  • ball nut axial deflection
    How to calculate the effect of preload on ball screw…
  • NB SGL slide guides in SGL-F P SGL-HTF SGL-E SGL-TE SGL-HTE SGL-HYF SGL-HYE and SGL-HTEX P versions for precise and rigid support of linear motion
    NB SGL slide guides for precise and rigid support of…
  • Linear Motion Trends: Consumer health-monitoring devices and more driving innovation
  • plain bearings
    Can plain bearings be used for cantilevered loads?
  • plain bearing speed
    What limits linear bearing speed? (Part 2)
Filed Under: Linear bearings, Slides + guides (all) Tagged With: igus, linear bearing
Leave a Reply Cancel reply
Your email address will not be published. Required fields are marked *
  • Saving energy and service cost with electric linear systems
RSS Most Recent Articles
  • Variable frequency drive with integrated functions for roll-to-roll applications
  • New four-quadrant PWM regenerative drive from American Control Electronics
  • High-torque synchronous belt for industrial applications
  • Integrated servo motor offers design benefits for mobile robotic applications
  • What is pitch in the context of conveyors?
Follow us on Twitter
Tweets by Linear_Motion
Follow us on Twitter@linear_motion
Add us on FacebookDesign World Network
Add us on LinkedInLinkedIn
Add us on YouTubeYouTube
Add us on InstagramInstagram
Copyright © 2019 · WTWH Media LLC and its licensors. All rights reserved.
