Ball nut preload: What effect does it have on bearing life?
September 11, 2019 By Danielle Collins Leave a Comment
ball screw
Preload reduces axial play, or backlash, caused by clearance between the balls and raceways.
Image credit: NOOK
Ball nut preload offers several benefits to screw assemblies, but the most common reason for using a preloaded ball nut is to reduce axial play, or backlash, caused by clearance between the screw and nut raceways. Reducing this axial play does two things. It improves the repeatability of the screw assembly — meaning the assembly is better able to return to the same position over repeated movements. And it increases the rigidity of the ball nut, which means the screw will experience less elastic deformation for a given load.
Despite the benefits in repeatability and rigidity, however, preload also has several potentially negative effects, particularly regarding the life of the screw assembly. The fundamental issue with adding preload to a ball nut (or any recirculating bearing) is that it produces an internal force on the nut, proportional to the amount of preload applied, and this internal force increases friction, heat, and wear.
ball nut preload
Fpr = internal force on ball nut due to preload
Xpr = preload amount
C = dynamic load rating of ball nut
For example, if a ball nut has preload of 5 percent (Xpr = 0.05) and a dynamic load rating of 16,0000 N, the force due to preload would be 800 N.
Effective load on ball nut with preload (4-point contact)
To determine bearing life accurately, the effective load on the nut should take into account the internal force due to preload, as shown in the following equation:
ball nut preload
Feff = effective load on the ball nut (to be used in bearing life equation)
Fa = applied external load on ball nut
Using our example above, if the applied external load is 1500 N, and the force due to preload is 800 N, the effective load on the nut is 1725 N.
ball nut preload
Note that the effective load equation shown above is valid for single ball nuts with preload via oversized balls, which experience 4-point contact with the raceways.
The balls in a preloaded nut can experience 4-point or 2-point contact with the raceways, depending on the preload method.
Effective load on ball nut with preload (2-point contact)
When preload is achieved via a double nut or a single nut with pitch or lead offset, which results in two-point contact between the balls and raceways, the effective load on the ball nut can be estimated with the following equation:
ball nut preload
Given the same preload and loading conditions as above, for a preloaded nut with 2-point contact, the effective load on the nut is 1550 N:
ball nut preload
Note that the when the preload method results in 4-point contact between the balls and raceways, there is more contact area to produce friction, heat, and wear, so fatigue will occur faster than for ball nuts with 2-point contact. Hence, the effective load on the ball nut with 4-point contact is higher than that of the ball nut with 2-point contact (1725 N > 1550 N).
When internal force due to preload (Fpr) can be disregarded
In some applications, the applied external load is sufficient to overcome the internal force due to preload. Although it might seem logical to think this would occur when the external load equals the internal force, it actually takes a significantly higher external load to negate the internal force.
When the applied external load on the ball nut equals 2.8 times the internal preload force, the preload force will be relieved and can be disregarded in the calculation of effective load.
Preload force can be disregarded in ball nut effective load calculation.
Preload force must be considered in ball nut effective load calculation.
Q: Why 2.8 times?
A: Because 2.8 represents the relationship between the maximum axial load on the ball nut and the preload force, as derived in this post.
  • ball screw standards
    Ball screw standards: What you need to know about DIN,…
  • ball nut axial deflection
    How to calculate the effect of preload on ball screw…
  • ball screw rigidity
    How to improve ball screw rigidity (with support-bearing selection and…
  • selecting ball screws
    Have a ball screw application? Check out these resources for…
  • How to calculate motor drive torque for ball screws
Filed Under: Applications, Ball + lead + roller screws, FAQs + basics, Featured
Leave a Reply Cancel reply
MOTION DESIGN GUIDES
Follow us on Twitter
Tweets by Linear_Motion
