How do miniature profiled rail guides compare to their full-size counterparts?
miniature profiled rails
Miniature profiled rails have a rail width of 15 mm or smaller and two rows of recirculating balls.
Image credit: IKO
The basic distinction between “standard” and “miniature” profiled rail guides is the width of the guide rail: profiled rails with a width of 15 mm or less — and the carriages that fit on them — are generally considered “miniature” by bearing manufacturers. (However, some manufacturers also produce 15 mm rail guides in standard versions, as we’ll explain below.)
In addition to the width of the rail, there are other key differences between standard and miniature profiled rail guides and carriages that designers and users should be aware of when specifying linear motion components.
Ball and raceway construction
First is the basic construction of the carriage, or runner block. Most standard profiled rail carriages use four rows of balls — two on each side of the carriage. But because of their compact dimensions, miniature versions use only two rows of balls — one row on each side of the carriage. This means that miniature profiled rail carriages have relatively lower load and moment capacities than would be expected of four-row carriages.
Miniature rail guides use Gothic arch geometry for four-point contact between the balls and raceways.
Image credit: Schneeberger
To help counter the loss of two ball rows, miniature guides typically use Gothic arch raceway geometry, which provides four points of contact between the balls and the raceway. This ball-raceway geometry gives the carriage the same load capacity in all four directions — downward, lift-off, and side loading — and provides relatively high moment load capacities.
This four-point contact gives them equal load capacity for downward, lift-off, and side loads.
Image credit: Nippon Bearing
Materials
Another difference between standard and miniature profiled rail guides concerns materials. Where standard profiled rail guides and carriages are made primarily from steel, miniature versions are offered as standard in stainless or corrosion-resistant steel — for both the guide rail and carriage, and in some cases, even the balls and recirculation pieces. This is especially beneficial in applications where corrosion-resistance is necessary, such as those involving chemicals, occasional exposure to water or high humidity, or even industry-specific requirements for stainless steel materials, such as those found in the food and packaging and medical industries.
One of the features that miniature and standard profiled rail guides have in common is the wide range of rail and carriage types. Case in point, miniature carriages come in short and long versions, and carriages and rails are also offered in wide versions, which can eliminate the need for using two rails in parallel in some overhung loading situations. The ability to support loads with just one rail or one carriage is especially important in applications where space is at a premium.
Sealing
Manufacturers also take different approaches to sealing for standard and miniature profiled rail guides and carriages. For standard versions, manufacturers often focus on ways to keep even the finest dust and fluid mist out of the carriage and to retain lubrication as efficiently as possible.
Miniature rails and carriages offer many of the same sealing options as standard versions, although in some cases, miniature versions can be used without seals.
Image credit: Chieftek Precision Co.
But miniature versions are often used in applications in the electronics, semiconductor, and medical industries, where the environment is relatively clean or may even be a certified cleanroom. For this reason, miniature profiled rail carriages are typically offered with several sealing options, including the option to omit seals altogether.
For those applications that do require protection against contamination and loss of lubrication, some manufacturers now offer miniature rail carriages with end cap seals that incorporate a lubrication reservoir, to reduce maintenance intervals and ensure sufficient sealing for contaminated environments.
Preload and accuracy class
Miniature rail carriages also have limited preload and accuracy class options. First, because of the small size of the balls used in miniature versions, preload is typically limited to 1 to 2 percent of the dynamic load capacity (as opposed to 8 or even 13 percent for standard versions), with clearance (slight play between the carriage and the rail) or light preload being the most common options.
Similarly, miniature profiled rails are typically offered in “normal” and “high” accuracy classes, with some manufacturers offering “precision” as the highest accuracy class — unlike standard profiled rail assemblies, which are also offered in “super-precision” and “ultra-precision” accuracy classes.
Miniature profiled rail assemblies are typically offered in “normal” and “high” accuracy classes, with some manufacturers also offering a “precision” accuracy class.
Image credit: Bosch Rexroth
Not all miniature profiled rails incorporate retainers to secure the balls in the carriage. Keep this in mind when assembling and disassembling miniature rail and carriage assemblies. If there’s no retainer, the balls will fall out of the carriage when it’s removed from the rail.
Feature image credit: Ewellix
Filed Under: Ball + roller guides, FAQs + basics, Featured, Linear bearings
